Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » User Setting Information Management (User Setting Information Management Service)
0R9W-1X9
This setting saves user information such as the user name and password that is set for each function by each user.
For example, if user A selected encrypted PDF for the file format when sending an e-mail and then sets a password in [Password Required to Open a Document] or [Password Required to Change Permiss.], the User Setting Information Management Service links the password (User Setting Information) set by user A with user A in User Authentication. Next time user A uses encrypted PDF, the settings screen for encrypted PDF is displayed with the password already entered, and the user does not have to enter the password.
The user setting information that this setting can associate with User Authentication is indicated below.
Password information used for encrypted PDF (See "Encrypting PDF Files" and "Printing Password Protected PDF Files.")
User name and password information used for SMTP Authentication (See "Specifying Authentication Method for SMTP Server.")
User name and password information used for the network storage location (See "Accessing the Advanced Box of Another Machine.")
User name and password information used for the Rights Management Server (See "Specifying Authentication Method for Rights Management Server.")
Information of the buttons on the Quick Menu (See "Keys on the Quick Menu Screen.")
User name and password used for LDAP server authentication (See "Specifying Authentication Method for LDAP Server.")
User name and password used for File TX/Browsing authentication (See "Specifying Authentication Method for File Server.")
User name and password used for the Personal Folder authentication (See "Specifying Personal Folders.")
If User Authentication is enabled, user setting information is automatically associated with user information and registered without you having to perform any special operations.
Registered information can only be deleted on the User Setting Information Management Service page.
To use the User Setting Information Management Service page, set [Use HTTP] in [Preferences] (Settings/Registration) to 'On.' (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
The amount of user information that can be registered is as follows:
Quick Menu button information: 5,000 items
User name/password information: 200 items
When setting the folder specified by the login service as a personal folder: 5,000 items
Maximum number of other items: 200 items
Only the System Manager or Administrator can perform operations on the User Setting Information Management Service page. For information on the type of administrator, see "Setting Administrators."
Displaying the User Setting Information Management Service Page
Log in as the Administrator or System Manager.
Click [User Setting Information Management Service].
Deleting the User Setting Information
You can delete password information for users or information of the buttons on Quick Menu.
You can also delete the shared setting information of all users, as well as specific user setting information.
Select the method to delete the User Setting Information from the User Setting Information Management Service page.
If you want to delete all users' setting information:
If you want to select and delete specified user setting information:
If you want to delete the shared setting information of all users:
Click [Delete All User Setting Information].
Click [Yes].
Click [Select User and Delete Setting Information].
Select the user information to delete → click [Delete].
Click [Yes].
Click [Delete Shared Setting Information of All Users].
Click [Yes].
You cannot delete the user setting information for the user who is logged in as an administrator. (See "Setting Administrators.")
The changed user setting information is enabled when the machine is restarted. It may take some time until the old user setting information is deleted. Wait for a while and restart the machine.
