Default Display after Auto Reset
06RH-06C
You can set whether the default screen set for [Default Screen after Startup/Restoration] in [Preferences] is displayed at startup after the Auto Reset mode initiates.
Press
(Settings/Registration).
Press [Preferences] → [Timer/Energy Settings] → [Function After Auto Reset].
Specify the following setting → press [OK].
Details of each item are shown below:
[Initial Function]:
The screen set for [Default Screen after Startup/Restoration] is displayed after the Auto Reset mode initiates.
[Selected Function]:
The screen set for [Default Screen after Startup/Restoration] is not displayed after the Auto Reset mode initiates.
Example: If [Copy] is set for [Default Screen after Startup/Restoration]
If [Initial Function] is set and the machine is idle for a certain period of time after an operation on the [Access Stored Files] screen, the Auto Reset mode initiates and the display returns to the default screen for [Copy].
If [Selected Function] is set and the machine is idle for a certain period of time after an operation on the [Access Stored Files] screen, the Auto Reset mode initiates and the display returns to the default screen for [Access Stored Files].
