Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
Full Adjust: Automatic after the machine prints and scans three sets of test pages
Quick Adjust: Press [Start]
No
No
[Correct Density]
Black Scan for Copy/Scan and Store (Mail Box), Black Scan for Send/Scan and Store (Other Than Mail Box), Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Correct Shading]
Densitometer Correction, Visual Correction
No
No
[Auto Correct Color Mismatch]
Start key
No
No
[Full Color Printing Vividness Settings]
Standard, Level 1, Level 2
Standard
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Saddle Stitcher Staple Repositioning]*1
Start key
No
No
[Change Fold/Stitch Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
[Adjust Fold Position]*1
0.00 mm
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Inside Main Unit]
Start key
No
No
[Clean Feeder]*1
Start key
No
No
[Original Scanning Area Cleaning Method]*2
Displaying cleaning method
No
No
*1
*2
Indicates items that appear only when you are using the imageRUNNER ADVANCE C5255/C5250.
