Item
Settings
Default Settings
Can be set in Remote UI
Device Information
Delivery Available
PCL*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
RGB Test Page
Yes, No
Yes
No
CMYK Test Page
Yes, No
Yes
No
RGB Color Chart
Yes, No
Yes
No
CMYK Color Chart
Yes, No
Yes
No
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
Item
Settings
Default Settings
Can be set in
Remote UI |
Device Information
Delivery Available
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
Letter, Legal, A4, B5, A3, B4, A5, 11x17, Executive, Statement, Env. KAKUGATA 2, Env. NAGAGATA 3, Env. YOGATANAGA3, Envelope Monarch, Env. No. 10, Envelope ISO-C5, Envelope DL, 12_5/8x17_11/16, 12x18
Letter
Yes
No
[Default Paper Type]
Thin, Plain 1, Plain 2, Recycled, Color, Pre-Punched, Bond, Heavy 1, Heavy 2, Heavy 3, Transparency, Letterhead, Tracing, 1-Sided Coated 1, 1-Sided Coated 2, 2-Sided Coated 1, 2-Sided Coated 2, Labels, Envelope, Tab
Plain 1
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Print Quality]
[Density]*1(See "Density.")
0
Yes
Yes
[Density (Fine Adjust)]*1
(See "Density (Fine Adjust).") |
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Density Fine Adjustment]
-2 to 2
0
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Image Compression]
(See "Image Compression.") |
Image Priority, Standard, Speed Priority
Standard
Yes
Yes
[Sharpness]
-3 to +3
0
Yes
Yes
[Trapping]
Trapping: On, Off
Off
Yes
Yes
Trapping Width: 1 to 3 pixel
1
Trapping Density: 25% to 100%
100
[Toner Volume Correction]
Normal, Gradation, Text
Normal
Yes
Yes
[Line Control]
(See "Line Control.") |
Resolution, Gradation
Resolution
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-1.90 to +1.90 inches
0.00
Yes
Yes
[Offset Short Edge (Front)]
-2.00 to +2.00 inches
0.00
Yes
Yes
[Offset Long Edge (Front)]
0.00
Yes
Yes
[Offset Short Edge (Back)]
0.00
Yes
Yes
[Offset Long Edge (Back)]
0.00
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
[Print After Completing RIP]
On, Off
Off
Yes
Yes
[Finishing]
(See "Finishing.") |
Off, Collate, Rotate+Collate*1, Rotate+Group*1, Offset+Collate*1, Offset+Group*1, Staple+Collate*1, Staple+Group*1
Staple Position (Staple+Collate):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), Double (Left) Staple Position (Staple+Group):
Grp Upp L-Corner, Grp Double (Top), Grp Upp R-Corner, Grp Double (R), Grp Lwr R-Corner, Grp Double (Btm), Grp Lwr L-Corner, Grp Double (L) |
Off
Yes
Yes
Off, Top, Bottom, Left, Right
Off
Yes
Yes
[Booklet]
On, Off
Off
Yes
Yes
[Saddle Stitch]*1
On, Off
Off
Yes
Yes
[Creep Correction]*1
Off, Auto, Correction Width
Off
Yes
Yes
[Transparency Interleaving]*1
(See "Transparency Interleaving.") |
Off, Blank, Printed
Off
Yes
Yes
[Copy Set Numbering]
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
[Small(12 point)], [Medium(24 point)], [Large(36 point)]
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Color]*1
Yellow, Magenta, Cyan, Black, Red, Green, Blue
Black
Yes
Yes
[Number Position Vertical]*1
-5/16 to +5/16 inches
0
Yes
Yes
[Number Position Horizontal]*1
0
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF, XPS
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.") |
None, PS, PCL, PDF, XPS
None
Yes
No
[Color Mode]
Auto (Color/B&W), Color, Black & White
Auto (Color/B&W)
Yes
Yes
[Gradation Settings]
Gradation: Off, Smooth 1, Smooth 2
Off
Yes
Yes
Graphics*1: On, Off
On
Image*1: On, Off
On
[Compressed Image Output]
Output, Display Error
Output
Yes
Yes
[Initialize]
Yes, No
No
Yes
*1
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Text: Resolution, Gradation, Error Diffusion
Resolution
Yes
Yes
Graphics: Resolution, Gradation, Error Diffusion
Gradation
Image: Resolution, Gradation, Error Diffusion
Gradation
[RGB Source Profile]
Text: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
Yes
No
Graphics: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
Image: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
[Output Profile]
Text: Normal, Photo
Normal
Yes
No
Graphics: Normal, Photo
Normal
Image: Normal, Photo
[Matching Method]
Text: Perceptual, Saturation, Colorimetric
Saturation
Yes
Yes
Graphics: Perceptual, Saturation, Colorimetric
Perceptual
Image: Perceptual, Saturation, Colorimetric
Perceptual
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[CMS(Matching) Selection]
Printer, Host
Printer
Yes
Yes
[CMS(Matching)/Gamma]
Text: Gamma, CMS
Gamma
Yes
Yes
Graphics: Gamma, CMS
Gamma
Image: Gamma, CMS
Gamma
[Gamma Correction]
Text: 1.0, 1.4, 1.8, 2.2
1.4
Yes
Yes
Graphics: 1.0, 1.4, 1.8, 2.2
1.4
Image: 1.0, 1.4, 1.8, 2.2
1.4
[Paper Save]
On, Off
On
Yes
Yes
[Advanced Smoothing]
Advanced Smoothing: Off, Smooth 1, Smooth 2
Smooth 1
Yes
Yes
Graphics: On, Off
Off
Text: On, Off
On
Item
Settings
Default Settings
Device Information
Delivery Available
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
60 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
5.50 to 47.24 inches
18.00 inches
Yes
No
[Y dimension]*1
3.89 to 12.59 inches
12.59 Inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Image: Gradation, Resolution, Error Diffusion
Gradation
(See "RGB Source Profile.") |
sRGB
Yes
No
sRGB
sRGB
[Output Profile]
(See "Output Profile.") |
Text: Normal, Photo
Normal
Yes
No
Normal
[Matching Method]
(See "Matching Method.") |
Saturation
Yes
Yes
Perceptual
Perceptual
[Gray Compensation]
(See "Gray Compensation.") |
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[CMS (Matching) Selection]
(See "CMS (Matching) Selection.") |
Printer, Host
Printer
Yes
Yes
(See "CMS (Matching)/Gamma.") |
Text: Gamma, CMS
Gamma
Yes
Yes
Gamma
Image: Gamma, CMS
Gamma
[Gamma Correction]
(See "Gamma Correction.") |
1.4
Yes
Yes
1.4
1.4
(See "Advanced Smoothing.") |
Smooth 1
Yes
Yes
Graphics: On, Off
Off
Text: On, Off
On
[BarDIMM]
(See "BarDIMM Menu.") |
Enable, Disable
Disable
Yes
Yes
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
*2
PCL Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Job Timeout]
0 to 3600 seconds
0
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*1
On, Off
On
Yes
Yes
[Matching Mode]
[RGB Input]
ICC Profile, D. Link Profile
ICC Profile
Yes
No
[CMYK Input]
ICC Profile
Yes
No
sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, None, Download Profile
sRGB
Yes
No
[CMYK Simulation Profile]
JapanColor(Canon, US Web Ctd(Canon, Euro Standard, None, Download Profile
None
Yes
No
[Use Grayscale Profile]
(See "Use Grayscale Profile.") |
On, Off
Off
Yes
No
[Output Profile]
Normal, Photo, TR Normal, TR Photo, Download Profile
TR Normal
Yes
No
[Matching Method]
Perceptual
Yes
Yes
[Device Link Profile]
(See "Device Link Profile.") |
[RGB Input(Light+ClrSpace)]
D50 + sRGB, D65 + sRGB, D50 + Adobe RGB, D65 + Adobe RGB, Profile Name
D50 + sRGB
Yes
No
[CMYK Input(Light+ClrSpace)]
D50 + JapanColor, Profile Name
D50 + JapanColor
Yes
No
[RGB Pure Black Process]
(See "RGB Pure Black Process.") |
On, Off
On
Yes
Yes
[CMYK Pure Black Process]
(See "CMYK Pure Black Process.") |
On, Off
On
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Gradation
85% to 115%
100%
Yes
Yes
[Spot Color Matching]
(See "Spot Color Matching.") |
On, Off
Off
Yes
Yes
[Composite Overprint]
(See "Composite Overprint.") |
On, Off
Off
Yes
Yes
Smooth 1
Yes
Yes
Graphics: On, Off
Off
Text: On, Off
On
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
*1
*2
PS Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Matching Mode]
ICC Profile, Kyuanos (Color)
ICC Profile
Yes
No
[ICC Profile Settings]
sRGB
Yes
No
JapanColor(Canon, US Web Ctd(Canon, Euro Standard, Download Profile
JapanColor(Canon
Yes
No
[Output Profile]
Normal, Photo
Yes
No
[Matching Method]
Perceptual
Yes
Yes
[Kyuanos Set. (Color Only)]
[Monitor Color Space]
sRGB, Adobe RGB
sRGB
Yes
No
[Environment Light]
D50, D65
D50
Yes
No
[Photo Correct.(Color Only)]
[Photo Optimizer PRO]
On, Off
Off
Yes
No
[Red-Eye Correction]
Red-Eye Correction: On, Off
Off
Yes
No
Red-Eye Correction Level: Weak, Standard, Strong
Standard
[Face Brightener]
Face Brightener: On, Off
Off
Yes
No
Face Brightener Level: Weak, Standard, Strong
Standard
[Halftones]
Gradation
Yes
Yes
[Gray Compensation]
On, Off
On
Yes
Yes
NTSC
Yes
Yes
*1
*2
Settings are applicable only for the Imaging mode of Direct Print.
Item
Settings
Default Settings
Device Information
Delivery Available
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*1
On, Off
On
Yes
Yes
[Matching Mode]
[RGB Input]
ICC Profile
Yes
No
[CMYK Input]
ICC Profile
Yes
No
sRGB
Yes
No
None
Yes
No
On, Off
Off
Yes
No
[Output Profile]
TR Normal
Yes
No
[Matching Method]
Perceptual
Yes
Yes
D50 + sRGB
Yes
No
D50 + JapanColor
Yes
No
On, Off
On
Yes
Yes
On, Off
On
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Gradation
85% to 115%
100%
Yes
Yes
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
Smooth 1
Yes
Yes
Graphics: On, Off
Off
Text: On, Off
On
NTSC
Yes
Yes
*1
*2
PS Printer only.
Item
Settings
Default Settings
Device Information
Delivery Available
[Matching Mode]
ICC Profile, Gamma, Kyuanos (Color)
ICC Profile
Yes
No
sRGB
Yes
No
sRGB
sRGB
[Output Profile]
Text: Normal, Photo
Normal
Yes
No
Normal
[Matching Method]
Saturation
Yes
No
Perceptual
Perceptual
[Gamma Settings]
[Gamma Correction]
1.4
Yes
No
1.4
1.4
sRGB, Adobe RGB
sRGB
Yes
No
[Environment Light]
D50, D65
D50
Yes
No
On, Off
Off
Yes
No
Off
Yes
No
Red-Eye Correction Level*1: Weak, Standard, Strong
Standard
[Face Brightener]
Off
Yes
No
Face Brightener Level*1: Weak, Standard, Strong
Standard
[Halftones]
Resolution
Yes
Yes
Gradation
Gradation
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
Smooth 1
Yes
Yes
Graphics*1: On, Off
Off
Text*1: On, Off
On
Text: sRGB, NTSC, Uniform RGB
sRGB
Yes
Yes
Graphics: sRGB, NTSC, Uniform RGB
sRGB
Image: sRGB, NTSC, Uniform RGB
sRGB
*1
*2
XPS Direct Print Printer only
Item
Settings
Default Settings
Device Information
Delivery Available
[Initialize PCL Hard Disk]*1
Yes, No
No
No
[Initialize PS Hard Disk]*1
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
*1
Item
Settings
Default Settings
Device Information
Delivery Available
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
When On is selected:
Select Jobs to Allow: Rsrvd Jobs, Rsrvd Jobs + Secure Print
Rsrvd Jobs
Yes
Yes
[PDL Selection (Plug-n-Play)]
UFR II, PCL5c*1, PCL6*1, PS3*1, Fax*1
UFR II
Yes
No
*1
