(Settings/Registration).|
[Address Book]:
Select to forward the received document to another machine (relay function).
[Confidential Fax Inbox]:
Select to store the received document in a Confidential Fax Inbox.
If the selected destination is a group address which contains a mail box, the file you are sending will not be forwarded to (and stored in) that mail box.
If you select [I-Fax] for <Receive Method:>, you cannot specify a WebDAV server as the forwarding destination. If the selected destination is a group address which contains a WebDAV server, the file is not forwarded to the WebDAV server.
To cancel a selected destination, select the destination again.
To view the detailed information for a selected destination, select the destination → press [Details].
Register destinations in the Address Book in advance. (See "Register Destinations.")
[Access No.] appears on the screen only if <Manage Address Book Access Numbers> for the Address Book is set to 'On' in [Set Destination] (Settings/Registration). (See "Managing the Address Book with Access Numbers.")
If you select a fax number as the forwarding destination, the subaddress and password registered in the Address Book are ignored.
You cannot select multiple destinations at the same time.
If the fax board is installed or the Remote Fax Kit is activated, you can specify fax numbers and group addresses which contain fax destinations as forwarding destinations.
You cannot store received documents in memory in the cases below. These numbers may vary depending on the remaining capacity of the hard disk.
When more than 1,500 documents or images are stored in all of the mail boxes.
When a total of approximately 6,000 pages of documents or images are stored in all of the mail boxes.
To send a link via e-mail to the Confidential Fax Inbox in which the document is stored, you must register an e-mail address in the Confidential Fax Inbox beforehand. For instructions on storing an e-mail address in the machine, see "Common Communication Settings for E-Mail/I-Fax."
You cannot select multiple Confidential Fax Inboxes.
If you set both <Store/Print Received File> and the Memory Lock mode to 'On', the received file is stored in the Memory RX Inbox. If you set Memory Lock to 'Off', the received file is printed automatically. (See "Specifying the Fax/I-Fax Inbox Settings.")
[TIFF]:
Sends the file in the TIFF format.
[PDF]:
Sends the file in the PDF format. You can also select [OCR (Text Searchable)], [Reader Extensions], or [Add Digital Signatures]. If you want to add a digital signature, you can select [Device Signature].
[XPS]:
Sends the file in the XPS format. You can also select [OCR (Text Searchable)] and/or [Device Signature].
[TIFF/PDF (Auto)]:
Sends the file in either the TIFF (Black-and-White) or PDF (Grayscale/Color) format. You cannot set [Divide into Pages] to 'On'.
[TIFF/XPS (Auto)]:
Sends the file in either the TIFF (Black-and-White) or XPS (Grayscale/Color) format. You cannot set [Divide into Pages] to 'On'.
[TIFF/JPEG (Auto)]:
Sends the file in either the TIFF (Black-and-White) or JPEG (Grayscale/Color) format. [Divide into Pages] is set to 'On'.
[PDF]:
Sends the file in the PDF format regardless of the color mode. You can also select [Trace & Smooth], [Compact], [OCR (Text Searchable)], [Reader Extensions], and/or [Add Digital Signatures]. If you want to add a digital signature, you can select [Device Signature].
[XPS]:
Sends the file in the XPS format regardless of the color mode. You can also select [Compact], [OCR (Text Searchable)], and/or [Add Digital Signatures]. If you want to add a digital signature, you can select [Device Signature].
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view TIFF files, software that supports the TIFF format (such as Imaging for Windows) is required.
To view PDF files, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view XPS files or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
For more information on file formats, see "Glossary."
[Access No.] appears on the screen only if [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration). (See "Managing the Address Book with Access Numbers.")
If the subaddress and password specified by the sending machine do not match the registered forwarding conditions, the documents are not forwarded to the forwarding destinations registered in Forward w/o Conditions. The faxed documents are not received.
You can store a forwarding destination for each receive type for received documents.
