You can set whether priority is given to scanning speed or to noise reduction when the document is scanned from the feeder.
This function is available only if you are using the imageRUNNER ADVANCE C5255/C5250.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Scan Settings].
Press [Scanner Noise Settings].
4.
Select [Speed Priority] or [Quiet] → press [OK].
