06RH-0C5
Auto Redial enables the machine to automatically redial the recipient's fax number if the recipient cannot be reached due to a busy line, or if a sending error occurs.
If you set Auto Redial to 'On', you can set how many times the machine redials, the redial interval, and whether the document should be resent when there is an error.
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Fax Settings].
Press [Auto Redial].
4.
Press [On].
Select [Off] if you do not want to enable [Auto Redial].
Press [Set Details].
Specify each setting → press [OK].
<Redial Times>:
Press [-] or [+] to set the number of redial attempts.
<Redial Interval>:
Press [-] or [+] to set the redial interval.
<Redial When TX Error>:
[Error and 1st Page]:
Auto Redial takes place if a sending error occurs. The first page of the sending file, the error page, and all subsequent pages are resent.
[All Pages]:
Auto Redial takes place if a sending error occurs. All pages of the sending file are resent.
[Off]:
Redialing does not take place if a sending error occurs.
5.
Press [OK].
