Outputting Different Sized Papers to the Same Output Tray
You can output different sized papers to the same output tray of the finisher.
This mode can be set when one of the Inner Finisher-E1, Staple Finisher-J1, or Booklet Finisher-J1 is attached. (See
"Inner Finisher-E1" or
"Staple Finisher-J1/Booklet Finisher-J1/External 2/3 Hole Puncher-B2.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Different Paper Sizes for Output Tray] → [On] → [OK].
If you set [Different Paper Sizes for Output Tray] to 'Off', printing may stop when the message <Remove the paper from the output tray.> appears. To resume printing, remove all of the paper from the output tray.
If you set both the Different Size Originals and Staple modes, outputs are stapled and collated, regardless of the Different Paper Sizes settings.
Even if you set [Different Paper Sizes for Output Tray] to 'Off', different paper size may be output to the same output tray if there is only a small amount of paper in the paper tray.
