Set Destination
Set Destination
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Address Lists]
Address List 1 to Address List 10, One-Touch
Yes
No
Print List: Yes, No
Yes
No
[Register Destinations]
Register New Dest., Details/Edit, Delete, Search by Name
Yes
Yes*1
[Rename Address List]
Rename
Yes
Yes
[Register One-Touch]
Register/Edit, Delete
Yes
Yes*2
[Change Default Display of Address Book]
Local, LDAP Server, Remote
Local
No
No
[Address Book PIN]
PIN: Seven digits maximum
(NULL)
Yes
Yes
[Manage Address Book Access Numbers]
On, Off
Off
Yes
Yes
[Include Pswd. When Exporting Address Book]
On, Off
Off
Yes
Yes
[Register LDAP Server]
Register, Details/Edit, Delete, Print List
Yes
No
[Auto Search When Using LDAP Server]
On, Off
On
No
Yes
[Register/Edit LDAP Search Conditions]
Display Name, Attribute Name
Yes
No
[Change Default LDAP Search Conditions]
Register, Initialize
No
No
[Acquire Remote Address Book]*3
[Acquire Address Book]
On, Off
Off
Yes
Yes
[Remote Address Book Server Address]
IP Address or Host Name
Yes
No
[Communication Timeout]
15 to 120 sec
30 sec
Yes
Yes
[Fax TX Line Auto Select Adjustment]
On, Off
On
Yes
Yes
[Make Remote Add. Book Open]
[Make Address Book Open]
On, Off
Off
Yes
Yes
*1
Indicates items that are not delivered as device information: Details/Edit, Delete, Search by Name
*2
Indicates items that are not delivered as device information: Edit, Delete
*3
Indicates items that appear only when the appropriate optional equipment is available for use.
» Settings/Registration » Settings/Registration Table » Set Destination
06RH-051
