Registering Shortcut Keys
You can register shortcut keys to display on the Send screen. You can register up to two desired buttons from [Options].
This feature is useful when you want to register frequently used functions.
Press [Function Settings] → [Send] → [Common Settings].
Press [Register Options Shortcuts].
4.
Press a shortcut button → select the setting to be registered in the button → press [OK].
To cancel the setting currently registered in a button, select [Unassigned].
5.
Press [OK].
Example: The registered shortcut buttons are displayed as shown below.
» Settings/Registration » Function Settings » Send » Common Settings » Registering Shortcut Keys
06RH-09U
