06RH-0CC
This mode enables you to change the send start speed. This is useful when there is difficulty initiating the sending of a document.
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Fax Settings].
Press [TX Start Speed].
4.
Select the desired start speed → press [OK].
If your document transmission is slow in starting, this may mean that the telephone lines in your area are in poor condition. Select a slower speed. You can select [33600 bps], [14400 bps], [9600 bps], [7200 bps], [4800 bps], or [2400 bps].
