Flow of Operations for Administrators
06RH-04E
If the System Manager Settings (System Manager ID/System PIN) are set
Press
(Settings/Registration).
Press [Log In].
Specify the following.
Press [System Manager ID] → enter the Department ID.
Press [System PIN] → enter the PIN.
4.
Press [OK].
5.
Display the desired setting from the list.
6.
Specify the setting → press [Close].
To move up one level, press [Up].
7.
When you finish specifying the settings, press [Log Out] at the bottom right of the screen to log out.
You can also press
(Log In/Out) to log out.
If the System Manager Settings are set and Department ID Management is used
Press [Dept. ID] → enter a Department ID.
Press [PIN] → enter a PIN.
Press [Log In].
You can also press
(Log In/Out) to log in.
Press
4.
5.
6.
You can also press
If the System Manager Settings are set and SSO-H is used
Press [User Name] → enter a user name → press [OK].
Press [Password] → enter a password → press [OK].
Press [Log In].
You can also press
Press
4.
5.
6.
You can also press
