Inserting a Job Separation Sheet between Print Jobs
06RH-07W
This mode enables you to insert a blank page before the first page of each print job from a selected paper drawer. This is useful when you want to separate one print job from another when printing multiple jobs.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Job Separator Between Jobs].
4.
Press [On] → [OK].
Select [Off] if you do not want to insert a job separation sheet between print jobs.
To change the paper source for the job separation sheets, press [Change] → select the paper source → press [OK].
