Checking the Procedure for Cleaning the Original Scanning Area of the Feeder
If originals are scanned using the feeder, there may be some cases in which the original cannot be scanned properly, or streaks appear on the copies. In this case, clean the original scanning area by following the directions displayed in [Original Scanning Area Cleaning Method] in [Adjustment/Maintenance] (Settings/Registration).
This item is displayed only if you are using the imageRUNNER ADVANCE C5255/C5250.
Press
[Adjustment/Maintenance] → [Maintenance] → [Original Scanning Area Cleaning Method].
Follow the instructions on the touch panel display.
