(1)
Click [+].
(2)
Enter [Name] and [Password], and click [Create Account].
The [Name] and [Password] entered here are needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
Folder Names
The folder name entered here is needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
(1)
Select the folder, and select [Files] and [Get Info].
(2)
Set [Ownership & Permissions] to [Read & Write] or [Write only].
(3)
Close the [Info] screen.
Computer Name
The name displayed for [Computer Name] at the top of the [Sharing] window is needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
(1)
Select the check boxes for [Services] - [Windows Sharing], and click [Accounts].
(2)
Select the check box for the account, and then click [Done].
(1)
Click [+].
(2)
Enter [Name] (or [Full Name]) and [Password], and click [Create Account].
The [Name] (or [Full Name]) and [Password] entered here are needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
Folder Names
(1)
(2)
Set [Sharing & Permissions] to [Read & Write] or [Write only].
(3)
Computer Name
(1)
Select the [File Sharing] check box, and then click [Options].
(2)
Select the check box for [Share files and folders using SMB].
(3)
Select the check box for the account that was created in Step 3, and then click [Done].
(4)
Click [+] under [Shared Folders], and add the folder created in Step 5 to the list.
