» Network Settings » Setting the Machine to Be Able To Send Scanned Documents » How to Save to a File Server (A Shared File Server) » Setting Up the File Server (Shared Folder) (Windows) » Setting Up a Shared Folder » Windows Vista/Server 2008 Sharing Settings
Sharing Files with Unrestricted Access
Windows Vista/Server 2008 has had special folders (public folders) for file sharing available from the beginning. Set up unrestricted shared folders using the public folders.
Sharing Public Folders
1
From the [Start] menu, select [Control Panel] and click [Set up file sharing].
2
Click on [] next to [Public folder sharing].
3
Select [Turn on sharing so anyone with network access can open, change, and create files], and then click [Apply].
Do not select [Turn on sharing so anyone with network access can open files]. If this is selected, it will not be possible to save scanned documents as files in the shared folders.
After the message [If you understand the security risks but want to share files without running the wizard, click here] appears, click on it.
When [User Account Control] appears
Click [Yes] or [Continue].
4
Click on [] next to [Password protected sharing].
5
Select [Turn off password protected sharing], and click [Apply].
Creating a Folder for Storing the Files
1
Display [Public] folder.
(1)
From the [Start] menu, select [All Programs] or [Programs] - [Accessories] - [Windows Explorer].
(2)
Click on [Public] folder.
2
Create a new folder inside the [Public] folder.
Example: share
Use single-byte alphanumeric characters for the folder name.
The folder name created here is needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
Sharing Files with Access Restrictions
1
Create a shared folder.
We recommend creating the shared folder in a location that would be easy to find later, such as directly under the C drive.
Example: C:\share
2
Right-click the created file, and select [Share].
3
Click [] to on the left of [Add], select the user with whom you wish to share, and click [Add].
4
Set permissions for the added user.
(1)
Click on the [Permission Level] column for the added user.
(2)
Select [Contributor] or [Co-owner].
(3)
Click [Share].
[Permission Level]
Reader: Can only view files.
Contributor: Can create, change and delete files. However, they cannot change permissions.
Co-Owners: Can perform all file operations, such as creating, changing, deleting and changing permissions.
5
Click the [Done] button.
07K4-0J1
