Setting the Machine Using WPS (PIN Code Mode)
07K4-0FW
Enter the PIN code generated by the machine to wireless LAN routers and/or access points for connection.
1
Switch the connection method to wireless LAN.
2
Press [
] (Menu).
3
Select <Network Settings> using [
] or [
], and then press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
4
Select <Wireless LAN Settings> using [
] or [
5
Press [OK].
Select <WPS PIN Code Mode> using [
] or [
7
Select <Yes> using [
8
Within 10 minutes, use the computer to enter the PIN code displayed on the screen into the wireless LAN router or access point.
For details on PIN code entry methods, see the instruction manual provided with the wireless LAN router or access point you are using.
If "Cannot find Access Point" appears, press [OK] to close the screen, and follow the procedure from Step 6 again.
9
Make sure the Wi-Fi indicator blinks.
When the wireless LAN router or access point is detected, the Wi-Fi indicator blinks.
The next screen is displayed for approximately 2 seconds, and then the Wi-Fi indicator lights.
When the message appears, press [OK] to close the screen and follow the procedure again from Step 6.
If you cannot detect the access point after retrying, see the following:
10
Wait until the machine sets the IP address automatically (approx. 2 min).
If you want to set the IP address manually, see the following.
