Network security
If the machine is connected to an unsecured network, your personal information might be disclosed to a third party. Take care to protect your personal data.
Network Tasks/Settings
Consult your network administrator to use the machine in your office.
IP Address
Even if the product's IP address is changed, the connection is maintained if the machine and the computer belong to the same subnet.
You may not be able to use the scan function if an IPv6 connection is used.
Device necessary for wired LAN connection
The machine does not come with a LAN cable, a router or a hub. Have cables or a hub ready as needed.
The machine supports 10BASE-T and 100BASE-TX connections. If you want to connect the machine to a 100BASE-TX Ethernet network, all the devices connected to the LAN (router, hub, LAN cable, and network board for computer) must support 100BASE-TX.
For details, refer to your instruction manual of those devices or contact the manufacturers. When the machine is connected to a switching hub
The machine may not be able to connect to a network even if your network settings are configured correctly. When this occurs, set a longer startup time.
