Category
Top » Network Settings » Basic Network Settings » Setting the IP Address » Setting the IPv6 Address
Category Top
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Connecting to Wireless LAN
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting the Machine Using WPS (PIN Code Mode)
Entering the PIN Code in the Wireless LAN Router/Access Point
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Setting the IPv4 Address
Attention (Setting the IPv4 Address)
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Setting the Machine to Be Able To Send Scanned Documents
Activating the Send Setting Utility
Configuring E-Mail Send Settings
How to Save to a File Server (A Shared File Server)
Setting Up the File Server (Shared Folder) (Windows)
Checking the Computer Settings
Setting Up a Shared Folder
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Windows 7/Server 2008 R2 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Additional Network Settings
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
07K4-0H6
Before setting the IP address, see "Attention (Setting the IPv6 Address)."
Specify IPv6 settings using the Remote UI after you have specified the IPv4 settings.
1
Start the Remote UI and log on in system manager mode.
2
Click [Settings/Registration].
3
Click [Network Settings] -> [TCP/IP Settings].
4
Click [Edit] in [IPv6 Settings].
5
Select the [Use IPv6] check box.
6
Specify the stateless address.
Clear the [Use Stateless Address] check box when not using a stateless address.
7
Follow the steps in the procedure below to use a manual address.
Proceed to Step 8 when not using a manual address.
(1)
Select the [Manual Address] check box.
(2)
Enter [IP Address].
(3)
Enter [Prefix Length].
(4)
Enter [Default Router Address] if necessary.
8
Set DHCPv6.
Select the [Use DHCPv6] check box to use stateful DHCPv6.
9
Click [OK].
10
Restart the machine.
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
