The computer and network device setup should be completed.
Otherwise, you are unable to use the machine in a network, even if you perform the following procedure.
The structure of your computer or networked device, the existence of router functions, setting methods and security settings vary depending on your environment.
For more information, see the instruction manual provided with the network device you are using, or contact the manufacturer. Consult your network administrator in advance to use the machine in your office.
Step 1
Switch its connection method to either wired LAN or wireless LAN.
Step 2
Connect the machine to either wired LAN or wireless LAN.
Step 3
Check automatically obtained IP addresses.
Step 4
Check the operation by displaying the Remote UI of the machine.
