Before connecting to wireless LAN, see "Attention (Connecting to a Wireless LAN)."
You cannot use wired LAN and wireless LAN at the same time
The machine's default connect method is "Wired LAN." When using a wireless LAN connection, it is necessary to switch the connection method to "Wireless LAN."
You can connect the machine to wireless LANs or wired LANs, but you cannot use both at the same time. When using a wireless LAN connection, do not connect a LAN cable to the machine. This may cause malfunctions.
Checking WPS Functions
Check whether the box or body of the wireless LAN router or access points that you are using supports the WPS function.
As an example, a symbol such as shown below can be seen on the shipping box or machine.
![]() This supports WPS (Wi-Fi Protected Setup).
If you are still not sure, contact the wireless LAN router or access point manufacturer.
Other setting method
Refer to the following to set "WPS PIN code method" and/or security settings.
