Security
If the machine is connected to an unsecured network, your personal information might be disclosed to a third party. Take care to protect your personal data.
The machine supports the following security. See the manual or contact the manufacturers for security information of your wireless LAN router or access point.
128(104)/64(40) bit WEP
WPA-PSK (TKIP/AES-CCMP)
WPA2-PSK (TKIP/AES-CCMP)
The machine's wireless LAN does not support IEEE 802.1X authentication.
Signal Strength
Since wireless LAN uses radiowave, it may have to detect wireless routers and/or access points nearby.
When more than one wireless LAN routers and/or access points which correspond to the access point name (SSID) and/or security information you specified, connect to the wireless LAN routers and/or access points with the strongest radiowave (RSSI).
Network Tasks/Settings
Consult your network administrator to use the machine in your office.
IP Address
Even if the product's IP address is changed, the connection is maintained if the machine and the computer belong to the same subnet.
You may not be able to use the scan function if an IPv6 connection is used.
Device necessary for wireless LAN connection
The machine does not come with a LAN cable, or any access points. Have cables or a hub ready as needed.
In order to use the machine in the wireless LAN environment, you need the 2.4 GHz LAN routers and/or access points which are compliant with IEEE802.11 (b/g or n).
For details, refer to your instruction manual of those devices or contact your manufacture. When the machine is connected to a switching hub
The machine may not be able to connect to a network even if your network settings are configured correctly. When this occurs, set a longer startup time.
