Category
Top » Network Settings » Basic Network Settings » Setting the IP Address » Setting the IPv4 Address
Category Top
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Connecting to Wireless LAN
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting the Machine Using WPS (PIN Code Mode)
Entering the PIN Code in the Wireless LAN Router/Access Point
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Attention (Setting the IPv4 Address)
Setting the IPv6 Address
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Setting the Machine to Be Able To Send Scanned Documents
Activating the Send Setting Utility
Configuring E-Mail Send Settings
How to Save to a File Server (A Shared File Server)
Setting Up the File Server (Shared Folder) (Windows)
Checking the Computer Settings
Setting Up a Shared Folder
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Windows 7/Server 2008 R2 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Additional Network Settings
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
07K4-0H4
Before setting the IP address, see "Attention (Setting the IPv4 Address)."
By default, the IPv4 address is obtained automatically.
Follow the steps in the procedure below to change the IP address setting.
1
Press [] (Menu).
2
Select <Network Settings> using [] or [], and then press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [] (Log In/Out).
3
Select <TCP/IP Settings> using [] or [], and then press [OK].
4
Select <IPv4 Settings> using [] or [], and then press [OK].
5
Select <IP Address Settings> using [] or [], and then press [OK].
6
Select the method for setting the IP address using [] or [].
<Auto Obtain>
Set the IP address using DHCP, BOOTP, RARP, or Auto IP.
<Manual Obtain>
Manually assign an IP address for the machine.
This setting can be specified only when <Select Protocol> and <Auto IP> in <Auto Obtain> are set to <Off>.
7
Change the IP address settings.
When <Auto Obtain> is selected
When <Manual Obtain> is selected
(1)
Change <Auto Obtain> settings.
<Select Protocol>
<Off>
Do not obtain an IP address automatically.
<DHCP>
Obtain an IP address automatically using DHCP. (The DHCP server needs to be running.)
<BOOTP>
Obtain an IP address automatically using BOOTP. (The BOOTP daemon needs to be running.)
<RARP>
Obtain an IP address automatically using RARP. (The RARP daemon needs to be running.)
<Auto IP>
<Off>
<On>
Obtain an IP address automatically.
(2)
Select <Apply> using [] or [], and then press [OK].
(1)
Enter the IP address.
After it has been entered, press [OK].
(2)
Enter the subnet mask.
(3)
Enter the gateway address.
8
Press [] (Menu) to close the menu screen.
9
Restart the machine.
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
