Category
Top » Network Settings » Basic Network Settings » Connecting to Wireless LAN » Setting the Machine Using WPS (PIN Code Mode) » Entering the PIN Code in the Wireless LAN Router/Access Point
Category Top
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Setting the IP Address
Setting the IPv4 Address
Attention (Setting the IPv4 Address)
Setting the IPv6 Address
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Setting the Machine to Be Able To Send Scanned Documents
Activating the Send Setting Utility
Configuring E-Mail Send Settings
How to Save to a File Server (A Shared File Server)
Setting Up the File Server (Shared Folder) (Windows)
Checking the Computer Settings
Setting Up a Shared Folder
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Windows 7/Server 2008 R2 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Additional Network Settings
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
07K4-0FX
Information of the wireless LAN router or access point can be set from a computer connected to the wireless LAN router or access point.
The contents described in this chapter are only examples. When setting up, be sure to read the instruction manual of the wireless LAN or access point you are using.
1
Start the Web browser by using the computer connected to the wireless LAN router or access point.
2
Enter "http://<IP address of the Wireless LAN Router/Access Point>/" in the address field and press the [ENTER] key on the keyboard.
If the IP address on the wireless LAN router or access point are not changed
See the instruction manual of the wireless LAN router or access point, or contact the manufacturer.
If the IP address on the wireless LAN router or access point are changed
Enter the changed IP address.
3
When the authentication screen is displayed, enter a user name and a password.
If the user name and password are not changed
If the user name and password are changed
Enter the changed user name and a password.
If authentication is successful, the settings screen for the wireless LAN router or access point is displayed.
4
Enter the PIN code on the settings screen.
