For Windows XP Professional
If Simple File Sharing is disabled, enable it using the following procedure.
We recommend creating the shared folder in a location that would be easy to find later, such as directly under the C drive.
Example: C:\share |
Use single-byte alphanumeric characters for the folder name.
The folder name created here is needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
(1)
Display the [Sharing] page.
(2)
Click [If you understand the security risks but want to share files without running the wizard, click here].
(3)
Select [Just enable file sharing].
(4)
Click [OK].
For Windows XP Home Edition
Sharing of files with access restrictions is not supported.
Example: C:\share |
(1)
Display the [Share] page.
(2)
Select [Share this folder].
(3)
Click [Permissions].
(1)
Enter [User Name].
(2)
Click [Check Name].
(3)
Click [OK].
(1)
Select users to allow access.
(2)
Select the [Allow] check box for [Full Control].
(3)
Click [OK].
Select the check box for [Full Control] here so that data scanned by the printer can be saved to the computer (file server).
If [Security] Type Is Displayed on the Shared Folder [Property] Screen
Proceed to Step 7.
If [Security] Type Is Not Displayed on the Shared Folder [Property] Screen
Proceed to Step 10.
(1)
Enter [User Name].
(2)
Click [Check Name].
(3)
Click [OK].
(1)
(2)
(3)
Click [OK].
