Category
Top » Network Settings » Setting the Machine to Be Able To Send Scanned Documents » How to Save to a File Server (A Shared File Server) » Setting Up the File Server (Shared Folder) (Windows) » Setting Up a Shared Folder » Windows 7/Server 2008 R2 Sharing Settings
Category Top
Basic Network Settings
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Connecting to Wireless LAN
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting the Machine Using WPS (PIN Code Mode)
Entering the PIN Code in the Wireless LAN Router/Access Point
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Setting the IP Address
Setting the IPv4 Address
Attention (Setting the IPv4 Address)
Setting the IPv6 Address
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Activating the Send Setting Utility
Configuring E-Mail Send Settings
Checking the Computer Settings
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Additional Network Settings
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
07K4-0J2
Sharing Files with Unrestricted Access
Windows 7/Server 2008 R2 has had special folders (public folders) for file sharing available from the beginning. Set up unrestricted shared folders using the public folders.
Sharing Public Folders
1
From the [Start] menu, select [Control Panel], and click on [View network status and tasks].
2
Click [Change advanced sharing settings].
3
Select [Turn on sharing so anyone with network access can read and write files in the Public folders].
4
Select [Turn off password protected sharing], and click [Save changes].
When [User Account Control] appears
Click [Yes].
Creating a Folder for Storing the Files
1
Display [Public] folder.
(1)
From the [Start] menu, select [All Programs] - [Accessories] - [Windows Explorer].
(2)
Open the hierarchy inside [Computer], and click on the [Public] folder.
2
Create a new folder inside the [Public] folder.
Example: share
Use single-byte alphanumeric characters for the folder name.
The folder name created here is needed by "How to Save to a File Server (A Shared File Server)." We recommend that you make a note of it so that you do not forget.
Sharing Files with Access Restrictions
1
Create a shared folder.
We recommend creating the shared folder in a location that would be easy to find later, such as directly under the C drive.
Example: C:\share
2
Right-click the file you created, and select [Shared with]-[Specific People].
3
Click [] to on the left of [Add], select the user with whom you wish to share, and click [Add].
4
Set permissions for the added user.
(1)
Click on the [Permission Level] column for the added user.
(2)
Select [Read/Write].
(3)
Click [Share].
Click [Yes].
[Permission Level]
[Read]: Can only view files.
[Read/Write]: Can create, change and delete files.
5
Click the [Done] button.
