] (Menu).
] or [
], and then press [OK].
] (Log In/Out).
] or [
] or [
The amount of time you must hold down the WPS button will depend on the model you are using.
Please refer to the instruction manual for your wireless LAN routers and/or access points. |
If "Cannot find Access Point" appears, press [OK] to close the screen, and follow the procedure from Step 6 again.
When the message appears, press [OK] to close the screen and start the procedure again from Step 6.
If you cannot detect the access point after retrying, see the following:
