(1)
Click [Edit] in [LPD Print Settings].
(2)
When using LPD printing
Select the [Use LPD Print] check box. When not using LPD printing
Clear the [Use LPD Print] check box. |
(3)
Click [OK].
(4)
Proceed to Step 5 .
(1)
Click [Edit] in [RAW Print Settings].
(2)
When using RAW printing
Select the [Use RAW Print] check box. When not using RAW printing
Clear the [Use RAW Print] check box. |
(3)
Click [OK].
(4)
Proceed to Step 5 .
(1)
Click [Edit] in [WSD Settings].
(2)
When Use WSD Printing
Select the [Use WSD Printing] check box.
When Not Using WSD Printing
Clear the [Use WSD Printing] check box.
(3)
Select the [Use WSD Browsing] check box to obtain information about the machine using the WSD port. (Once the [Use WSD Printing] check box is selected, it cannot be cleared.)
(4)
When Use WSD Scanning
Select the [Use WSD Scanning] check box.
When Not Using WSD Scanning
Clear the [Use WSD Scanning] check box.
(5)
Select the [Use Computer Scanning] check box to use a computer scanner. (Once the [Use WSD Scanning] check box is selected, it cannot be cleared.)
(6)
Select the [Use Multicast Discovery] check box to respond to a multicast search request.
(7)
Click [OK].
(8)
Proceed to Step 5 .
