For more information on how to check, refer to the instruction manual of the wireless LAN router or access point, or contact the manufacturer.
It may be indicated as access point name or network name.
It may be indicated as encryption key, WEP key, WPA/WPA2 passphrase, PSK or pre-shared key.
Checking for SSID and Network Keys
If the settings for the wireless LAN router or access point have changed, are not described or if you are not sure of the settings, see the following.
] (Menu).
] or [
], and then press [OK].
] (Log In/Out).
] or [
] or [
] or [
] or [
] or [
] or [
], and then press [OK].|
(1)
Select the authentication method with [
] or [ ], and then press [OK].![]() |
(2)
Select <Edit WEP Key> using [
(3)
Select a WEP key using [
] or [ ], and then press [OK]. Select the key number to be used for encryption which you wrote down in Step 2.![]() |
] or [
] and press [OK].
] or [
(1)
Press [
] (Tone), and then select <Entry Mode>. |
(2)
Enter the network key.
You can enter it using the numeric keys. |
(3)
After entering, select <Apply> using [
] or [ ], and then press [OK]. |
(1)
Select <Select WEP Key> using [
(2)
(1)
Select the character using [ ] or [ ], and then press [OK] to enter. |
(2)
(1)
After entering the network key, select <Select WEP Key> using [
(2)
When the following message appears, press [OK] to close the screen and check to make sure that the type of encryption, the authentication method or encryption method, the network key are correctly entered. If not, enter the network key again.
If you cannot detect the access point after retrying, see the following:
