Before changing settings
Make sure the machine is turned ON and connected to a network.
To use DHCP, BOOTP, or RARP
One of the following can be used: DHCP, BOOTP, or RARP.
When the machine is restarted, the IP address obtained using DHCP, BOOTP and RARP is displayed.
(The IP address obtained using DHCP, BOOTP, or RARP overwrites the current IP address.) It takes approximately two minutes to confirm that DHCP, BOOTP, or RARP can be used. We recommend that unused protocols be disabled.
To use DHCP
You may not be able to print after turning the power OFF and ON to restart the machine. This is because a new IP address has been assigned.
When using DHCP, consult your network administrator and perform one of the following:
Set the machine so that it uses the same IP address every time it starts up
The IP address has higher priority when <Auto IP> is set to <On>.
