Category
Top » Network Settings » Setting the Machine to Be Able To Send Scanned Documents » How to Save to a File Server (A Shared File Server) » Setting Up the File Server (Shared Folder) (Windows) » Setting Up a Shared Folder
Category Top
Basic Network Settings
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Connecting to Wireless LAN
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting the Machine Using WPS (PIN Code Mode)
Entering the PIN Code in the Wireless LAN Router/Access Point
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Setting the IP Address
Setting the IPv4 Address
Attention (Setting the IPv4 Address)
Setting the IPv6 Address
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Activating the Send Setting Utility
Configuring E-Mail Send Settings
Checking the Computer Settings
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Windows 7/Server 2008 R2 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Additional Network Settings
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
07K4-0HX
After checking that the necessary functions are installed, set up shared folders for saving documents scanned from the printer as files. There are the following two ways to set up shared folders.
Unrestricted Shared Folders
"Unrestricted shared folders" are convenient when you want to share files freely with all computers on the network.
All computers on the network can access unrestricted shared folders. It is not necessary to specify user names or passwords in order to access them.
Restricted Shared Folders
"Restricted shared folders" are convenient when you want to distinguish users who can access shared folders.
In order to access this type of shared folder, it is necessary to specify an account (user name and password) that is set for the shared folder when accessing it. The shared folder cannot be accessed unless the account is known.
