If a Shared Folder Has Not Been Set
In order to send data to shared folders on the network from the printer, it is necessary to set up shared folders on the computer (file server) side where the data will be sent, not just using settings on the printer side. See the following sections for shared folder settings.
Note that the settings are registered in one-touch keys.
The settings are registered in one-touch keys. Check that there is an unregistered one-touch key before specifying the settings.
(1)
Enter [System Manager ID] and [System Manager Password].
(2)
Click [Logon].
[One-touch Speed Dial Number]
From the drop-down list, select the One-touch Speed Dial number you want to register.
[Name for One-touch Speed Dial Number]
Enter the registered name of the one-touch key.
[Computer Name of Store Destination]
Enter the host name of the computer where the shared folder will be set up.
[Shared Folder Name on Store Destination Computer]
Enter the shared name.
[Access Restriction to Shared Folder ]
Select the [Set] or [Not Set] check box based on the access restrictions of the shared folder.
[Registered User Name]
When [Set] is selected for [Set Access Restrictions to Shared Folder], enter the user name.
[Password to Access]
When [Set] is selected for [Set Access Restrictions to Shared Folder], enter the password.
