Category
Top » Network Settings » Additional Network Settings » Setting IPv4 DNS
Category Top
Basic Network Settings
Switching the Connection Method to Wireless LAN or Wired LAN
Connecting to Wired LAN
Attention (Connecting to a Wired LAN)
Connecting to Wireless LAN
Attention (Security when using a wireless LAN product)
Setting the Machine Using WPS (Push Button Mode)
Setting the Machine Using WPS (PIN Code Mode)
Entering the PIN Code in the Wireless LAN Router/Access Point
Setting by Manually Selecting an Access Point
Setting by Manually Entering SSID
Checking the SSID or Network Key of the Wireless LAN Router/Access Point
Attention (Connecting to a Wireless LAN)
Setting the IP Address
Setting the IPv4 Address
Attention (Setting the IPv4 Address)
Setting the IPv6 Address
Attention (Setting the IPv6 Address)
Checking IP Address Settings
Attention (Confirming IP Address Settings)
Checking the Network Connection
Attention (Checking the Network Connection)
Setting Up Your Computer to Print and Send Faxes (Windows Only)
Selecting the Connection Method (LPD/RAW/WSD)
Configuring Printer Settings on Your Computer
Attention (Configuring Printer Settings on Your Computer)
Setting the Machine to Be Able To Send Scanned Documents
Activating the Send Setting Utility
Configuring E-Mail Send Settings
How to Save to a File Server (A Shared File Server)
Setting Up the File Server (Shared Folder) (Windows)
Checking the Computer Settings
Setting Up a Shared Folder
Windows 2000/Server 2003 Sharing Settings
Windows XP Sharing Settings
Windows Vista/Server 2008 Sharing Settings
Windows 7/Server 2008 R2 Sharing Settings
Setting Up the File Server (Shared Folder) (Macintosh)
Setting Up the File Server (File Sharing) (UNIX/Linux)
Setting the Speed and Duplex
Specifying a Delay Before Establishing the Network Connection
Setting IPv4 DNS
Setting IPv6 DNS
Attention (DNS Settings)
Setting the WINS Server
Setting the SMB
Setting MTU Size
Managing the Machine
Check Wireless LAN Information
Checking the MAC Address
Collapse all|Expand all
Setting IPv4 DNS
07K4-0J8
Before specifying the DNS settings, see "Attention (DNS Settings)."
DNS (Domain Name Service) is a service used for associating a host name (a name of a computer or a printer on a TCP/IP network) with an IP address.
1
Start the Remote UI and log on in system manager mode.
2
Click [Settings/Registration].
3
Click [Network Settings] -> [TCP/IP Settings].
4
Click [Edit] in [IPv4 Settings].
5
Specify DNS settings.
[Primary DNS Server Address]
Enter the IP address of the primary DNS server.
[Secondary DNS Server Address]
Enter the IP address of the secondary DNS server.
[Host Name]
Enter the host name to be added to the DNS server. Up to 47 characters can be entered.
[Domain Name]
Enter the name of the domain to which the machine belongs. Up to 47 characters can be entered.
* For example, "example.com"
[DNS Dynamic Update]
Select this check box to use DNS Dynamic Update.
Once the check box is selected, you do not need to refresh the IP address of the machine or specify [Host Name] and [Domain Name].
[DNS Dynamic Update Time]
Set the dynamic update interval (from 0 to 48 hours).
6
Specify mDNS settings.
Proceed to Step 8 when not using mDNS.
[Use mDNS]
Select the check box to use the mDNS.
[mDNS Name]
Enter an mDNS name.
7
Set DHCP option settings.
[Acquire Host Name:]
Select the check box to acquire the host name from the DHCP server.
Select the check box to update the host name dynamically from the DHCP server.
Restart the machine after changes have been made to the DHCP option settings.
8
Click [OK].
