If you attempt to use the machine without registering the necessary information correctly, the machine may not function properly.
If this setting is incorrect, you will be unable to communicate with other machines. Be sure to check the type of telephone line that you are using, and make the correct setting.
<Time Zone>:
The standard time zones of the world are expressed globally in terms of the difference in hours (± up to 12 hours) from GMT*1 (± 0 hours). A time zone is a region throughout which this time difference is the same.
<Daylight Saving Time>:
In some countries, time is temporarily advanced throughout the summer season. This practice is called "Daylight Saving Time."
It is necessary to register a separate fax number if you have an additional line. (See "Fax Line Settings.")
If a fax board installed, the Remote Fax function cannot be used.
It is necessary to register a separate unit name if you have an additional line. (See "Fax Line Settings.")
If you set the machine to print the sending record at the top of the recording paper, and not all of the items are registered, only the registered items and the total number of original pages are printed.
You can set the machine so that the sending record is not printed. However, for users in the United States, this information must be printed at the top of every fax document that you send. Therefore, [TX Terminal ID] in <Common Settings> in Send in [Function Settings] (Settings/Registration) must always be set to 'On'. (See "Printing the TX Terminal ID.")
You can select the login user's name as the Sender Name if you are using the User Authentication login service. (The login name appears in <100> of Sender Names (TTI).) For more information on the User Authentication login service, see "How User Authentication Works."
To display/print the Sender Name instead of the unit name, set [Sender Name (TTI)] in Options. (See "Selecting the Sender's Name When Sending a Fax.")
To use the machine as a remote fax client machine, you must set [Remote Fax TX Settings]. (See "Remote Fax TX Settings.")
You can also specify to automatically synchronize the date and time with a server on the network. (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
To receive a fax on the client machine when using the Fax function with the Remote Fax Kit, you must specify the settings on the server machine so that the received fax is forwarded to the client machine as an I-fax.
