Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Adjusting Density Manually
0R9W-0UA
You can adjust the density to the most appropriate level for the original when scanning.
Press [Fax].
Specify the destination → press [Options] → [Density].
Press or to adjust the density for the original → press [OK] → [Close].
