Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Using Subaddresses for Secure Transmission
0R9W-0WW
You can send faxes using the subaddress function (a function that attaches a password and sends faxes to the destination's memory box).
If you enter a password with the subaddress when sending a fax, the document data is sent to a memory box in the destination's fax and stored. This function is convenient when sending confidential documents as faxes.
When using the subaddress function, the destination's fax must support subaddress communication.
Faxes can be sent using the subaddress function only when using a device that is provided with a fax board as standard.
For details about the options required for this function, see "Optional Products Required for Each Function."
Click [Enter Destination].
See "Faxing" or "Specifying the Default Fax Settings" on how to display the fax driver screen.
Specify the communication mode and fax number.
Select [G3] for [Communication Mode].
Select [Fax Number] for [Fax Number/URI].
Enter a fax number for [Fax Number].
You can select an address book from [Address Book List] in the [Select Destination] tab.
For details about how to select an address from the address book, see "Faxing."
Select [Use Subaddress] → enter a subaddress and password in [Subaddress] and [Password] → click [Send].
4.
Click [OK].
If you are using a subaddress, data is sent to and stored in a memory box in the destination device. The data is output when the correct password is entered.
The display may vary according to the operating system and fax driver version you are using.
When sending to multiple addresses, you must specify the destinations from an address book in the [Select Destination] tab. For details about registering destinations in an address book, see "Registering a Person in an Address Book."
You can set an outside line dialing prefix for each communication mode.
To set [Communication Mode], the communication mode needs to be correctly set to match the connection environment in the [Device Settings] tab. If it is not set correctly, wrong transmissions and transmission errors may occur.
