0R9W-0SS
You cannot register new destinations in a group destination that is stored in a one-touch button. The destinations must be registered in the one-touch buttons beforehand.
Storing/Editing One-Touch Buttons
Press [Fax] → [One-Touch].
Press [Register] → select a one-touch button to store or change → press [Register/Edit].
If you know the three digit number for the one-touch button, you can press
→ enter the Register from LDAP Server digit number of the desired one-touch button using
(numeric keys).
If you select a one-touch button in which a destination is already stored, proceed to step 3.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
 (Fax)
 (Group)
Select the type of destination to register.
Press [Fax].
Press [One-Touch Name].
Enter a name → press [OK].
Press [Next].
Press [Group].
Press [Next].
Select a destination to store in the group address from [Add from One-Touch] → press [OK].
You can only select destinations that are already stored in one-touch buttons to be part of a one-touch button group address.
→ enter the three digit number of the desired one-touch button using
(numeric keys).
If you select [Register from LDAP Server]:
Press [Register from LDAP Server].
Select the destination from the search results → press [Next].
You cannot select multiple destinations at the same time.
To cancel a specified destination, select the destination you want to register again.
If necessary, edit the contents of the destination.
The information that you can obtain via the LDAP server consists of only names and fax numbers.
Press [OK].
4.
Press [Close] → [OK].
Deleting One-Touch Buttons
Press [Register] → select a one-touch button to delete → press [Delete].
If you know the three digit number for the desired one-touch button, you can press
(numeric keys).
 (Fax)
 (Group)
Press [Yes].
4.
Press [Close]→ [OK].
Destinations stored in one-touch buttons also appear in the Local Address Book.
