To receive documents in memory, you must first set [Use Fax Memory Lock] or [Use I-Fax Memory Lock] to 'On'. (See "Specifying the Fax/I-Fax Inbox Settings.")
You cannot store received documents in the Memory RX Inbox in the following cases. (These numbers may vary depending on the remaining capacity of the hard disk.)
When a total of 2,000 documents have been stored in the Fax/I-Fax Inbox
When a total of 6,000 pages have been stored in the Fax/I-Fax Inbox
