Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Canceling a Job
Canceling a Job
0R9W-0S5
Canceling a Job That Is Scanning
Press [Cancel] on the screen that appears while the machine is scanning.
Press [Yes].
You can cancel a send job by pressing (Stop), while the job is being scanned.
Canceling a Job Being Sent or Waiting to Be Sent
Press [Status Monitor/Cancel].
Press [Send] → [Job Status].
Select [Fax] from the drop-down list .
4.
Select the job that you want to cancel → press [Cancel].
You cannot select multiple jobs and cancel them all at once. Select and cancel one job at a time.
If [Restrict Access to Other User Jobs] in [Management Settings] (Settings/Registration) is set to 'On', jobs sent by other users are displayed as asterisks ('********'), and operations cannot be performed on them. If you are logged in as the Administrator, the jobs of all users are displayed, and you can view the details of or cancel the jobs.
5.
Press [Yes].
Check the destinations for the fax job → press [Current Jobs] or [All Jobs]. If you do not want to cancel any job of the Sequential Broadcast, press [Current Jobs].
The canceled job appears as <NG> (No Good) on the Log screen.
You can press (Stop) to cancel a send job that is currently being scanned.
