Top » Optional Products/Software » System Configuration » Optional Products Required for Each Function
0R9W-04F
The tables below describe the optional products that are needed to use each function, the available combination of options that can be installed simultaneously, and the limitations when installing optional products.
Hardware Options
Function
Optional Product Required
Notes
Finished Stamp
Stamp Unit-B1
Adding Paper Sources
Cassette Feeding Unit-AL1
Collate/Group/Offset/Staple/Staple-Free/Manual Staple
Restrictions for the Above Modes/Offset Jobs
Inner Finisher-G1
The Inner Finisher-G1 cannot be used with the Inner 2way Tray-J1, Staple Finisher-U1, or Booklet Finisher-U1.
Collate/Group/Offset /Staple
Staple Finisher-U1 or Booklet Finisher-U1
Inner Finisher-G1, Inner 2way Tray-J1, and Copy Tray-J2 cannot be attached to the Staple Finisher-U1 or Booklet Finisher-U1.
Saddle Stitch Booklet, Saddle Fold
Booklet Finisher-U1
Inner Finisher-G1, Inner 2way Tray-J1, and Copy Tray-J2 cannot be attached to the Booklet Finisher-U1.
Additional Output Tray under the Scanner Unit/Collate/Group/Rotate 90 Degrees
Inner 2way Tray-J1
Inner 2way Tray-J1 cannot be used with the Inner Finisher-G1, Booklet Finisher-U1.
Additional Output Tray on the Right Side of the Machine/Collate/Group/Rotate 90 Degrees
Copy Tray-J2
Copy Tray-J2 cannot be used with the Staple Finisher-U1 or Booklet Finisher-U1.
Department ID Management Using Card
Copy Card Reader-F1
System Options
Function
Notes
Barcode Print
Barcode Printing Kit
Fax Function
Display Fax Function/Memory Sending/Register Sender Name/Use Authentication User Name as Sender Name/Confirm Entered Fax Numbers/Subaddress Sending/Fax TX Report/Fax Activity Report/Fax Multi TX Report/Fax User Data List/Set Line
Super G3 FAX Board or Remote Fax Kit
To use these functions on the Remote Fax Kit, the imageRUNNER ADVANCE series (Remote Fax server machine) with Super G3 FAX Board must correctly be connected with this machine.
Fax Function
Direct Sending/Register Unit Telephone Number/Register Unit Name/Volume Settings/Allow Fax Driver TX/ECM TX/Auto Redial/Send Start Speed/PIN Code Access/Memory Receiving/ECM RX/Subaddress Receiving/Receive Start Speed/Receive Password/Forwarding Settings/Fax RX Report/Confidential Fax Inbox RX Report
Super G3 FAX Board
Fax Function
Select Line/Tone/Pause/Onhook
To use [Select Line], you must have more than one telephone line.
Fax Function
Select TX Line/Select Line Type/Onhook/Manual Sending/Check Dial Tone Before Sending/Pause Time
Super G3 FAX Board
Remote Fax Function
(Settings as a client machine)
Send Remote Fax/Send Remote Fax Settings
Remote Fax Kit
To use these functions, another machine with the Super G3 FAX Board must correctly be connected with this machine.
Fax Function with 2 Lines
Super G3 2nd Line Fax Board
Super G3 FAX Board
The following functions are only available with Line 1 (the standard line):
Audible Tones
On-Hook
Trace & Smooth PDF
Universal Send Trace & Smooth PDF Kit
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
User Signature PDF/XPS
Universal Send Digital User Signature Kit
Secure Watermark
Secure Watermark
Restricting Document Duplication/Track Users
Document Scan Lock Kit
Embedding and analyzing TL code are available.
HDD Data Encryption
HDD Data Encryption Kit
Removable HDD Management
Removable HDD Kit
The Removable HDD Kit is only used for removing the standard-equipped 250 GB hard disk of the machine.
Viewing Web Pages
Web Access Software
Encrypted Secure Printing
Encrypted Secure Print Software
Registering Combinations of Functions
Workflow Composer
Voice Guidance
Voice Guidance Kit/Voice Operation Kit
Voice Operation
Voice Operation Kit
The Super G3 FAX Board and Remote Fax Kit cannot be used at the same time.
