Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Specifying the Default Fax Settings
0R9W-0WS
This section describes how to access the fax driver screen from the [Control Panel] and how to specify the default fax settings.
You can edit address books, register cover sheet templates, set page formats, etc.
To change the default fax settings, you must log on to your computer as a member of the Administrators group.
Click [] (Start) → [Devices and Printers].
For Windows 8/8.1/Server 2012/2012 R2: From the desktop, display the charm bar to the right of the screen, and click or tap [Settings] → [Control Panel] → [Devices and printers].
For Windows Vista/Server 2008, click [] (Start) → [Control Panel] → [Printer].
For Windows XP Professional/Server 2003, click [Start] → [Printers and Faxes].
For Windows XP Home Edition, click [Start] → [Control Panel] → [Printers and Other Hardware] → [Printers and Faxes].
Right-click the icon of the fax whose settings you want to configure → click [Printing Preferences].
Specify the desired settings in the fax driver screen → click [OK].
Click each tab and specify the desired items.
You can configure the following functions.
Editing the address book (see "Registering a Person in an Address Book," "Registering a Group in an Address Book," "Importing Address Book Entries," "Exporting Address Book Entries," and "Changing the Address Book Export Destination."
For details about other functions, view Help (see "Viewing Help").
When faxing, you can change the default settings in the fax driver screen whenever required.
The display may vary according to the operating system and fax driver version you are using.
You can set an outside line dialing prefix for each communication mode. To set [Communication Mode], the communication mode needs to be correctly set to match the connection environment in the [Device Settings] tab. If it is not set correctly, wrong transmissions and transmission errors may occur.
