Entering a New Fax Number
0R9W-0SA
You can specify a fax number using
(numeric keys),
, and
. You can also specify several numbers in succession, and send the original to several destinations in a single operation (Sequential Broadcast).
Press [Fax].
Enter the recipient's fax number using
(numeric keys),
, and
For instructions on performing this operation from the Fax screen, see
"Fax Basic Features Screen."
If [Set Details] is displayed:
Press [Set Details].
Press [Subaddress].
Enter the recipient's subaddress using
(numeric keys),
, and
Press [Password].
Enter the password using
(numeric keys),
, and
If the recipient did not set a password for the target subaddress, you do not need to enter a password.
If you want to attach a subaddress to your send job, make sure that the recipient's fax machine supports ITU-T (International Telecommunication Union - Telecommunication Standardization Sector) standard subaddresses. (See "Sending with a Subaddress.")
Select the telephone line → press [OK].
For information on selecting the line to use, see
"Selecting the Telephone Line When Sending a Fax."
If [Subaddress] is displayed:
Press [Subaddress].
(numeric keys),
, and
Press [Password].
(numeric keys),
, and
Press [OK].
Press [OK].
You cannot insert a pause at the beginning of a number.
If you enter a pause at the end of the number, the pause is always 10 seconds long.
