Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » Specifying Destinations » Favorite Settings
Favorite Settings
0R9W-0SF
If you frequently send documents with the same document settings to the same destination, it is convenient to store these settings in a favorite button. Then, when you need to specify the destination, all you have to do is select the favorite button containing your stored document settings and the desired destination, and send your document.
To use this feature, you must first register the desired document settings and destinations in a favorite settings button. For instructions on registering destinations and settings in a favorite settings button, see "Registering/Editing Favorite Settings."
Press [Fax] → [Favorite Settings].
Select the desired Favorite Settings button.
Press [Yes].
You can manually change the settings recalled from the selected button before you send your documents.
If multiple destinations are stored in the selected button, the destinations may not be listed in the order in which they were set.
The destinations registered in the one-touch buttons stored in the favorite buttons of the client machine are not updated even if those registered in the one-touch buttons of a server machine are updated. Confirm if the destination is updated when you cannot send to the registered destinations.
