Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Faxing
Faxing
0R9W-0WR
The procedure for faxing a document created in an application is as follows.
Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
Select [Print] from the [File] menu of the application.
Select your fax → click [Print] (or [OK]).
In Windows 8/8.1/Server 2012, if you want to send a fax from the Windows Store app, display the charm bar to the right of the screen, and tap [Devices] → the printer you are using → [Print] (for Windows 8.1, tap [Devices] → [Print] → the printer you are using → [Print]). If the message [The printer requires your attention. Go to the desktop to take care of it.] is displayed, move to the desktop and proceed to step 3.
Specify the send address in the [Fax Sending Settings] dialog box.
Enter the destination directly:
Specify the destination from the Address Book:
Select [Enter Destination] tab.
Specify the communication mode and fax number.
Select [G3] for [Communication Mode].
Select [Fax Number] for [Fax Number/URI].
Enter a fax number for [Fax Number].
If you have set [Special] tab → [Security Settings] → [Confirm Fax Number/URI when Setting Destination], enter the fax number in [Confirm Fax Number]. For details, see the Help (see "Viewing Help").
You cannot send a fax by specifying a URI with the printer model you are using.
Select the address book from [Address Book List] in the [Select Destination] tab.
Select the destination → click [Add to Destination List].
In [Address List], you can narrow down and search for destinations.
By clicking [Edit Address Book], you can edit address books.
By clicking [Add Destination]/[Edit Destination], you can add new destinations or edit destinations without using an address book.
4.
If you want to set send options, do so by displaying the [Detailed Settings] dialog box.
5.
If you want to attach a cover sheet, configure the settings in the [Cover Sheet] Dialog Box → click [OK].
For details about cover sheet attachment, see "Attaching a Cover Sheet."
6.
If you want to save a fax image, select [Store Sent Fax Information and Image].
7.
Click [Send].
Faxing begins.
Some printer models enable you to confirm the status of the printer and stop printing from a print cancelation display (see "Status Monitor/Cancel").
If a printer icon is displayed in the task tray at the bottom right of your computer monitor, you can stop sending a fax from your computer. Double-click the printer icon → click the name of the file you want to stop sending → click [Document] → [Cancel].
You cannot access or edit the address book if you do not have access permission to the destination folder of the address book. If this is the case, log on as user having access permission to the folder, or click [Specify a Folder] in the [Edit Address Book] tab, and specify a folder, such as the [My Documents] folder, that you have write permission for as the destination folder of the address book. For details, see "Changing the Address Book Export Destination."
The number of destinations that you can send to at one time depends on the conditions under which the cover sheet has been attached. For details, view Help (see "Viewing Help").
The display may vary according to the operating system and fax driver version you are using.
