Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending/Receiving a Fax » When Problems Occur » Trouble Sending Fax Documents
0R9W-0W8
Canceling Transmissions.
How do you cancel a transmission while a document is being scanned?
Are you sending a fax document using the Direct Sending mode?
Press (Stop) on the control panel, or press [Cancel] on the touch panel display.
How do you cancel a transmission after the document has been scanned?
Press [Status Monitor/Cancel] → [Send] → [Job Status] → select [Fax] from the drop-down list. Then select the document that you want to cancel → press [Cancel] → [Yes]. However, documents that are being sent may not be canceled even if you press [Cancel]. (See "Canceling a Job Being Sent or Waiting to Be Sent.")
Cannot Send Documents.
Is the destination setting correct?
Check the destination setting of the recipient.
Is the destination stored in the Address Book correct?
Check the destination in the Address Book. (See "Checking/Editing/Deleting a Stored Address.")
Has trouble occurred in the remote machine?
Check to make sure that the remote machine can receive documents. If it cannot, check to see whether the recipient's machine has been turned Off, is out of recording paper, or has insufficient available memory.
Cannot Send Faxes.
Is the telephone line type set correctly?
Check the type of telephone line that has been set. (See "Fax Line Settings.")
If you are sending with a subaddress setting, did you enter the correct subaddress and password for the destination?
Check the subaddress and password settings.
Is the line connected to a private branch exchange switchboard or terminal adapter?
Set [Check Dial Tone Before Sending] to 'Off'. (See "Checking the Dial Tone before Sending.")
The Memory Is Full.
Are unwanted documents stored in memory?
Delete documents with transmission errors to make more memory available.
(See "Operations from the Send Screen.")
Delete unwanted documents from the Memory RX Inbox. (See "Checking the Detailed Information for/Displaying an Image/Deleting a File in the Memory RX Inbox.")
Delete unwanted documents from the Confidential Fax Inbox. (See "Checking the Detailed Information for/Displaying an Image/Deleting a File in the Memory RX Inbox.")
Delete unwanted documents from the Mail Box. (See "Operations for Files Stored in a Mail Box.")
The Document Does Not Print Clearly at the Recipient's Machine.
Is the platen glass clean?
Use your machine to make a copy of the document, and check it for streaks. If streaks appear, clean the platen glass. (See "Originals Cannot Scanned Properly (Cleaning the Platen Glass).")
The Density of the Documents Sent to a Recipient Is Too Light.
Is the Density setting set towards  (Light) and the Original Type setting set to [Photo] when you send your document?
Change the Density setting to  (Dark) and the Original Type setting to [Text]. Try sending your document again. (See "Setting Original Type" and "Adjusting Density Manually.")
The Machine Will Not Transmit Using a Subaddress.
Are the subaddress and password of the remote machine specified correctly?
Check to see if the machine has a subaddress function.
Check with the remote party to see if the specified subaddress and the RX password at both this machine and the remote machine are the same.
Are the subaddress and password for the destination stored in the Address Book correct?
Check the subaddress and password settings stored in the Address Book for the destination.
The Recipient's Machine Is Slow to Switch Over to the Receiving Mode, and Errors Always Occur.
Is a pause inserted in the fax number?
If you are sending to a machine that is slow in switching over to fax receiving, insert a pause after the destination's fax number.
