Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Exporting Address Book Entries
0R9W-0X5
You can save data registered in the address book as a CSV (*.csv) file or a Canon Address Book file (*.abk). You can use the saved file in other applications.
Click [Select Destination] → [Edit Address Book].
See "Faxing" or "Specifying the Default Fax Settings" on how to display the fax driver screen.
Click [Export] in the [Edit Address Book] dialog box.
If you have selected [Protect with Password when Exporting Address List] in the [Security Settings] dialog box of the [Special] tab - [Security Settings] - [Protect with Password when Exporting Address List], a dialog box for entering a password is displayed when you click [Export]. For details, see Help (see "Viewing Help").
Enter the file name → click [Save].
Select the type of the file to export from [Save as type]: CSV Files (*.csv) or Canon Address Book (*.abk)
If you have selected a CSV file, specify the separators used in the file.
The specified address book is saved as a file.
You cannot access or edit the address book if you do not have access permission to the destination folder of the address book. If this is the case, log on as a user having access permission to the folder, or click [Specify a Folder] in the [Edit Address Book] tab, and change the destination folder of the address book to a folder that you have write permission for (see "Changing the Address Book Export Destination").
The display may vary according to the operating system and fax driver version you are using.
