0R9W-0UH
This mode enables you to remove the shadows and lines that appear when scanning various types of originals. There are three types of Erase Frame: [Erase Original Frame], [Erase Book Frame], and [Erase Binding].
Make sure to place your original on the platen glass. If you place originals with binding holes in the feeder, it may damage the originals.
This mode deletes the dark borders and frame lines that appear around the scanned image if the original is smaller than the specified paper size. You can also use this mode to create a blank border around the edge of the scanned image.
Example: Scanning an STMT original as LTR size.
Not Selected
Selected
Press [Fax].
Specify the destination → press [Options] → [Erase Frame].
Press [Erase Original Frame] → [Change] → select the original size → press [Next].
You can only set the Erase Original Frame mode for the original sizes shown on the touch panel display.
4.
Set the erase frame width.
If you want to set the same width for all four borders:
Press [-] or [+] to set the erase frame width.
If you want to set the width for each border independently:
Press [Adjust Independently].
Select the desired borders → press [-] or [+] to set their respective Erase Frame widths.
To return to the screen for setting the same amount of space for all four borders, press [Uniform Width].
5.
Press [OK] → [Close].
This mode deletes the dark borders, as well as center and contour lines that appear when you scan an original such as a magazine or a book.
Erase Book Frame
Not Selected
Erase Book Frame
Selected
Press [Fax].
Press [Erase Book Frame] → [Change] → select the original size → press [Next].
You can set the Erase Book Frame mode only for the original paper sizes shown on the touch panel display.
4.
Press [Center] and [Sides] → press [-] or [+] to set their respective Erase Frame widths.
If you want to set the top, left, center, right, and bottom widths independently:
5.
This mode deletes the shadows that appear on scanned images from binding holes on originals.
Erase Binding
Not Selected
Erase Binding
Selected
Press [Fax].
Press [Erase Binding] → [Next].
4.
Specify the location of the binding marks → press [-] or [+] to set the erase frame width.
When you specify the location of the binding holes, assume that the original is face up.
5.
If you are using [Erase Binding], the borders you do not select are also erased by 1/8" (4 mm).
