Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Favorite Settings
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Preview
Printing the TX Report
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
Selecting a Profile for Faxing
Sending a Fax from a Computer (Mac OS)
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Viewing Help
Setting the Output Range
Editing Address Books
Displaying an Address Book (Mac OS X 10.5)
Displaying an Address Book (Mac OS X 10.6 and later)
Adding/Editing Address Information (Cards)
Importing an Address Book
Exporting an Address Book
Top » Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Selecting a Profile for Faxing
0R9W-0X1
You can apply registered fax settings by simply selecting an item from [Profile] list.
Select [Print] from the [File] menu of the application.
Select your fax → click [Properties].
In Windows 8/8.1/Server 2012, if you want to send a fax from the Windows Store app, display the charm bar to the right of the screen, and tap [Devices] → the printer you are using → [Print] (for Windows 8.1, tap [Devices] → [Print] → the printer you are using → [Print]). When you print in this way, you can only set some of the print functions. If the message [The printer requires your attention. Go to the desktop to take care of it.] is displayed, move to the desktop and proceed to step 3.
Select a profile from the [Profile] list according to your objective.
You can select a profile in the [Select Destination] or [Special] tab.
4.
Click [OK].
For information on registering a profile, see "Registering a Profile for Faxing."
Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
The display may vary according to the operating system and fax driver version you are using.
