Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Printing a Booklet (Windows)
Printing a Booklet (Mac OS)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac OS)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Secured Print
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Digitizing Paper Documents » Adding an Image Scanned via Network Scanner to a Document
0R9W-21R
Color Network ScanGear 2 is software for scanning from a machine on the network. It can be started from applications compatible with TWAIN (such as Adobe Photoshop, Adobe Acrobat, and Office 2000 or later versions of Microsoft Word/Excel/PowerPoint).
Benefits of Using Color Network ScanGear 2
You can make adjustments when scanning.
You can adjust the brightness and density as well as specify the scanning area.
You can store the scanned data in various formats.
You can process scanned images and store the images with a specified format (such as BMP/JPG/PDF) using application software.
Required Condition
Color Network ScanGear 2 is installed on the computer.
Your machine (scanner) and computer are connected to the network.
This section describes how to add images scanned using Color Network ScanGear 2 to a document.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Selecting a Scanner with Color Network ScanGear 2
Turning the Scanner Online from the Machine
Scanning with Color Network ScanGear 2
When using Color Network ScanGear 2 for the first time, it is necessary to select the scanner using Color Network ScanGear 2 Tool.
If a scanner has already been selected, proceed to the procedure in "Turning the Scanner Online from the Machine."
Color Network ScanGear 2 Tool cannot be used at the same time as the Color Network ScanGear 2 driver.
Start Color Network ScanGear 2 Tool on Windows.
For Windows XP
Click [Start] → [All Programs] → [Color Network ScanGear 2] → [Color Network ScanGear 2 Tool].
For Windows 7
Click [] (Start) → [All Programs] → [Color Network ScanGear 2] → [Color Network ScanGear 2 Tool].
Color Network ScanGear 2 Tool starts.
Click [Discover] to automatically search for the scanner to use.
The scanners that are found are displayed in [Select Scanner from List].
If you select to automatically search for scanners, scanners on the subnet (network with the same network ID) are displayed in the list.
You can also specify the scanner to use by clicking [Address] and entering the IP address or host name of the machine.
Select the scanner to use → click [Select].
To check whether you can use the selected scanner, click [Test Connection].
4.
Click [Exit].
Press [Scanner] on the Main Menu screen.
If the Main Menu screen is not displayed, press [Main Menu].
Press [Online].
The scanner is now online.
Start Color Network ScanGear 2 from an application and paste the scanned image to the document.
Open the document to paste the image to in the application.
Start Color Network ScanGear 2 from the application.
For Microsoft Office 2007/2010
(1) Click [] (Start)/[Start] → [All Programs] → [Microsoft Office] → [Microsoft Office Tool] → [Microsoft Clip Organizer].
(2) Click [File] → [Add Clips to Organizer] → [From Scanner or Camera].
(3) Select Color Network ScanGear 2 from [Device] → click [Custom Insert].
For Adobe Photoshop
Click [File] → [Scan] → [Color Network ScanGear 2].
For Adobe Acrobat
(1) Click [File] → [Create PDF] → [From Scanner].
(2) Select [Color Network ScanGear 2] in [From Scanner] → click [Scanner Options].
(3) Select [Show Scanner's Native Interface] in [User Interface] → click [OK].
(4) Click [Scan].
Select [Platen Glass] in [Scanning Method] on the [Basic Settings] page.
You can also select the feeder in [Scanning Method] to scan your original from the feeder.
4.
Place your originals on the platen glass. Place your originals with the side to scan face down, as indicated below.
5.
Specify scan conditions such as the color mode and resolution on the Color Network ScanGear 2 screen.
6.
To preview, click [Preview].
If the preview is successful, the prescanned image is displayed in the preview area.
The following operations can be performed using the prescanned image:
You can specify the scanning area.
You can enlarge the displayed image using the toolbar and adjust the image from settings on the [Advanced Settings] sheet.
7.
Click [Scan].
Scanning starts.
After you click [Scan], do not perform operations on the Color Network ScanGear 2 screen until a dialog box indicating the scanning process appears.
If the Color Network ScanGear 2 screen does not automatically close after scanning is complete, click []/[] (End) to close it.
When scanning is complete, the scanned image is displayed in the document.
For Office 2007/2010, scanned images are saved to [Color Network ScanGear 2] in [My Collections] in Microsoft Clip Organizer. You can select a saved image and drag and drop it to a location in a document to paste the image.
