Customizing the Screen Display
0R9W-23F
The imageRUNNER ADVANCE enables you to customize the screen display of the touch panel display. By placing buttons for frequently used functions in a visible position, or creating shortcut keys for combinations of functions that are frequently used, you can increase the efficiency of operations.
Customizing the Main Menu Display
Executing a Series of Functions with One Button
By registering a series of functions, such as scanning a 2-sided original and sending the data to your computer as a compact PDF, you can execute this series of functions with the press of one button.
Recalling Settings Used on Another Machine
You can use a Quick Menu button from another machine on this machine without registering the settings again.
